[Resr] SKZR-250-U1
Wasze oprawy oświetleniowe
[Resr] SKZR-250-U1
Postprzez ResR » 21 lipca 2009, 17:47
I have a russian street light fixture from 1977. It operates 250 and 400 watt mercury discharge light bulbs only. At the back of the block of flats on the third floor balcony it lights the whole backyard.
Bulb in the fixture is HgLI250W.
ResR
Dołączył(a): 20 lipca 2009, 21:29
Re: SKZR-250-U1
Postprzez Whites86 » 21 lipca 2009, 18:05
cool :) do you have a possibility to turn it on in a day ?
do you have more photos in bigger size ?
Re: SKZR-250-U1
Postprzez DocBrown » 21 lipca 2009, 18:32
Very nice lantern :)
It's impossible to operate 250W, and 400W lamps correctly in one fixture without replacing ballast, I think, that your is designed for 250W mercury lamps, because it is SKZR-250, not SKZR-400 :mrgreen:
Of course 400W lamp, and bigger will also work, but it wouldn't light with full power and brightness :mrgreen:
Could you show us more, and bigger photos of this lantern ?
If it's possible please show us night photos :)
Re: SKZR-250-U1
Postprzez Bartek » 21 lipca 2009, 18:46
Great lantern :)
Proabably it can operate only 250W lamps. If you change balast you can use another lamps.
Please, show more photos ;)
Bartek
Zdjęcia: 10
Re: SKZR-250-U1
Postprzez ResR » 21 lipca 2009, 18:48
i have bigger photos (original 3072x2304 is too big) and i can turn it on even at midnight (did it yesterday, forgot to picture).
250W off
250W warming
250W hot white
400W off
400W warming
400W hot white, old bulb.
edit: russian lamp can take both, i have seen one bulb in that same kind fixture for four years in active use.
ResR
Re: SKZR-250-U1
Postprzez Bartek » 21 lipca 2009, 18:56
Thanks :!:
When was made this 400W bulb :?:
Who produced it :?:
BTW wellcome guest from abroad.
Where are you from :?:
Bartek
Zdjęcia: 10
Re: SKZR-250-U1
Postprzez DocBrown » 21 lipca 2009, 18:59
Great photos !
Optimal format for forum is 1000x750 :)
Could you open the ballast chamber, and make some photos ?
Re: SKZR-250-U1
Postprzez ResR » 21 lipca 2009, 19:26
400W bulb is made by "Tungsram" in Hungary, 175864 is it's production code, i don't have any idea when the bulb was made, i saved it from vandals after the most of lamps in kehtna were replaced with Malagas (omfg) with steel poles and old fixtures were just piled with bulbs still inside (for not very long, i filled my school bag and two plastic bags with bulbs first hour i found out :twisted: ) to the trashyard. There was a mixture of polish OUS250 and russian lamps, most were emptied from copper at the same night by unknown persons. It was in summer 2003.
I´m from Estonia.
Ballast chamber:
ResR
Re: SKZR-250-U1
Postprzez Utilizer » 21 lipca 2009, 19:51
malaga is everywhere :(
nice relic very nice
Re: SKZR-250-U1
Postprzez neon44 » 21 lipca 2009, 21:34
ResR great fixture. We call it "can for sardines" and now we know its name.
Please take some photos in the night too
